AdrianL's avatar
AdrianL
Access Point - cannot reach routerlogin
Hi there!     (I have no real previous experience with access points and the like so excuse me for my lack of knowledge haha..)     I bought a NETGEAR Access Point (WAC104) a few days ago and I...
  • AdrianL's avatar
    AdrianL
    Oct 11, 2020
    Thank you so much for the reply, antinode!
    A friend of mine just managed to figure it out for me. In case anyone ever comes across this post, here's how we did it;
    We went into the command prompt (cmd) and wrote down 'arp -a' (Windows laptop). Then it was basically a matter of writing down the IP addresses in one of those MAC Adress Lookup sites until one of them mentioned NETGEAR.
    That IP adress directed me to NETGEAR's routerlogin and I was able to login using 'admin' as the username and 'password' as.. well.. the password.
    No idea if any of this makes sense but it worked for me, haha. The IP listed on the label on the back of the access point didn't work and all the basic ones didn't either - probably because my router already assigned an IP and Gateway.
    Cheers!
    Adrian
