TheFrench's avatar
TheFrench
Access Point Mode not working anymore
Hello all,   I have purchased a Netgear N300 wifi router WNR2000v5 in March 2016. I initially configured it as a AP as it was the recommended solution ( http://kb.netgear.com/app/answers/detail/a_i...
  • ElaineM's avatar
    ElaineM
    Nov 02, 2016
    Things happens unexpectedly. I would suggest that you contact support and ask for an RMA.
    Tell them that your settings are lost and that you always need to reboot the router to get the connection back.
