TheFrench
Oct 11, 2016Aspirant
Access Point Mode not working anymore
Hello all, I have purchased a Netgear N300 wifi router WNR2000v5 in March 2016. I initially configured it as a AP as it was the recommended solution ( http://kb.netgear.com/app/answers/detail/a_i...
- Nov 02, 2016
Things happens unexpectedly. I would suggest that you contact support and ask for an RMA.
Tell them that your settings are lost and that you always need to reboot the router to get the connection back.
ElaineM
Oct 14, 2016NETGEAR Employee Retired
Hi TheFrench
Welcome to the community!
Can you provide more information about your network setup?
Where's the WNR2000v5 connected? Where's the modem physically located? Is there an existing router in the network?
Do you just have a cable going into your room? Who is your ISP?
Unplugging the router shouldn't erase the settings that was saved onto the router. I suggest that you upgrade or reflash the firmware of the router.
The firmware and the instructions on how to upload it can be seen here. After firmware update, factory reset the router then configure it to the way it was.
TheFrench
Oct 24, 2016Aspirant
Hello Elaine; thank you for your help !
My router is connected in the wall of my living room, my computer is in my living room, a few feets from the router.
The modem is in the basement of the building, I live on the 3rd floor.
The ISP is AT T Uverse.
I tried to upgrade but I already had the last version. I installed it anyways following the instructions but it did not changed anything unfortunatly:
Everytime I unplug the router and replug it (I unplug the router every night and during work), I switch on my computers but none of them can connect to the wifi, I have to open routerlogin.net, and the windows Internet status is red for disabled.
I click on it, it says this:
And then Internet works. But I have to do this process everyday, everytime I switch off the router.
Besides, I have noticed my internet connection is deadly slow the afternoon/evenning but good the early morning/morning. (3 mo/s the morning if I download a file, no youtube lagging. The evenning my internet download is not stable and will range and go up and down from 100 ko/sec to 400 ko/sec. I can barely watch youtube videos)
I have no idea why it is happening, my neighboors says they can watch netflix in HD no issue...
Any help or insights will be much appreciated, thank you !!
- ElaineMOct 25, 2016NETGEAR Employee Retired
Do you know the brand of the modem being used?
Can you describe how do you connect the router to the modem?
Is there an Ethernet cable in your room where you attached it at the back of the WNR2000v5?
Which port is it connected at the back of the NETGEAR router?
Is your neighbor experiencing the slow connection on those hours too?
- TheFrenchOct 25, 2016Aspirant
My landlord said Cisco
I use one ethernet cable (the yellow one provided in the netgear pack) to plug my router to the wall outlet of my living room. This wall outlet can accept only ethernet cable.
the ethernet cable is between my router and the wall outlet. I think behind the wall there is a cable or something similar (behind the wall outlet there is a small storage room and I remember seeing a cable here going into the wall behind the outlet.
I don't understand ?
No, my neighboor was really surprised to see I had slow speed because they can watch Netflix/Youtube no problem the evenning.
Is it helping?
Do you happen to know the exact model number of the Cisco modem?
Modem is connected to which port on the NETGEAR router?
Is it going to the Internet port?
