welshmatt983
Apr 19, 2022Aspirant
Access point not working
I have a Netgear router which has been used as an access point for past few years, I remember I had a bit of trouble setting up at the time. Anyway its worked fine for past 2 years but last night dat...
wcalifas
Apr 20, 2022Prodigy
to get to the settings most likely you'll have to do a hard reset by pressing the reset button for 30 seconds with a paper clip and re-do the setup you had as an access point if you decide to update the firmware. Did you try restarting your router and maybe plugging the ethernet cord on a different port on the router to see if maybe you have one of the ports go bad?
