welshmatt983
Apr 19, 2022Aspirant
Access point not working
I have a Netgear router which has been used as an access point for past few years, I remember I had a bit of trouble setting up at the time. Anyway its worked fine for past 2 years but last night dat...
michaelkenward
Apr 21, 2022Guru - Experienced User
welshmatt983 wrote:
How do I get into the net gear settings page if I can't connect to the internet, maybe needs to update firmware or something?
If you can see the wifi from the access point, look for its IP address.
I use the Network Map in the desktop genie.
genie | Product | Support | NETGEAR
Then aim a browser at the IP address.
welshmatt983
Apr 22, 2022Aspirant
I've managed to figure out problem. I have a long 25m ethernet which I have used for years, although when I unplugged from router and tested in nearby tv it worked, it must not be working as good as when I moved my netgear router closer to main router and tested with 2m ethernet it was working perfectly. Its strange how it works fine with TV but router to router stopped working!
