scrungy
Apr 07, 2021Aspirant
Access point WNDR4500 help
I am trying to configure a WNDR4500 as an access point. I tried the same thing with an RN6250 with the same results. Configuration: network 192.168.0.x gateway 192.168.0.1 This is a Servegate ro...
antinode
Apr 08, 2021Guru
> [...] if you have a better suggestion then tell him [...]
Already done. Did you read this stuff before "contributing" to it?
Which part of '[...] Get the User Manual (at least). Look for "access
point".' did you find unclear?
> [...] instead of trying to correct.
Yow. If you don't like corrections, then you might try posting less
nonsense. Do you think that leaving your "500" suggestion uncorrected
would be more helpful to anyone, now or in the future?
wcalifas
Apr 08, 2021Prodigy
You don't offer any good advice get squared away.
