moklemat000
Dec 06, 2018Aspirant
Access Point
I have a TP-Link router, more specifically the Archer C7, and I want to setup the Netgear Access Point so that it can connect to the router wirelessly and be able to plug a machine into the access po...
- Dec 07, 2018
There is support for the WN604 at the end of this link:
>>> WN604 | Product | Support | NETGEAR<<<
See the section Enable Wireless Bridging.
By the way, you have posted your message in the section of this community given over to General WiFi Routers.
The WN604 is a Wifi Access Point.
You might get better replies, and find other answers, over in the appropriate section:
michaelkenward
Dec 07, 2018Guru - Experienced User
