rbshah's avatar
rbshah
Access ReadyShare
I have been using this router for a while as a main router with DHCP enabled on it and was hooked up to my modem. Recently i got a new router. Hence i moved this router to one of my rooms and connect...
  • michaelkenward's avatar
    May 22, 2020
    rbshah wrote:
    Hence i moved this router to one of my rooms and connected an ethernet cable from my main router's LAN port to this router's LAN port.
    Did you put the R6100 into wireless access point (AP) mode?
    Should be WAN (Internet) port, not LAN port.
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
    General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
