BobFord
Mar 23, 2021Aspirant
Access Router RAX200 via Browser
My router IP is 192.168.1.1 but I can't access this through browsers (tried multiple browsers across multiple pc's) and even tried to delete browser history and use routerlogin.net and .com all don't...
Mar 23, 2021Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the router?
- BobFordMar 23, 2021Aspirant
The router is connected to a BT Modem connected to the broadband circuit
Version: 1.0.3.102
- plemansMar 23, 2021Guru - Experienced User
Which Bt Modem?
some have their own integrated routers which cause a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
disconnect the modem from the router, reboot the router, then try the routerlogin address
If that doesn't work, open a command prompt and type ipconfig
the default gateway would be the ip address.
It's the Huawei EchoLife HG612
I'll reset the modem later when work is finished and report back
I've managed to connect in the past - that's how I setup the router in the 1st place
I may have to do a factory reset and see if that solves the problem
