Buyamac
Oct 24, 2020Aspirant
Add another RBR850 satellite or extender?
Hi, I have a three piece RBR850 system. One base and two satellites, all on the first floor. It covers the 2nd floor very well, but loses significant speed/latency on the third floor (my office and ho...
- Oct 24, 2020
I would try spacing them out properly first. Then if you truly do need another one, I'd look at the mesh satellites and not extenders. They'd integrate with the system.
Oct 24, 2020Guru - Experienced User
How big is your home that you have the router and all of the satellites on the same floor?
Have you tried staggering them? They're omnidirectional.
Like put the primary router on floor 2 and then the sateiiites on floor 1 and floor 3?
- BuyamacOct 24, 2020AspirantIt’s 5000 sq ft. But I am forced to put base on far left side of house and based on 30ft recommendation distance for satellite, I can’t put one close enough on 2nd floor to get full
Coverage to my wife’s office on the opposite side of the house on the first floor (away from base. 3rd unit covers screened porch and outdoor pool area.- plemansOct 24, 2020Guru - Experienced User
30ft is the minimum distance they need. You can go further, you just have to check the backhaul connection speed/quality.
- BuyamacOct 24, 2020AspirantSounds good. However if I determine I need to add something to the third floor, can I hardwire a satellite and add it to the current mesh or is the extender the correct product?
