Buyamac
Oct 24, 2020Aspirant
Add another RBR850 satellite or extender?
Hi, I have a three piece RBR850 system. One base and two satellites, all on the first floor. It covers the 2nd floor very well, but loses significant speed/latency on the third floor (my office and ho...
- Oct 24, 2020
I would try spacing them out properly first. Then if you truly do need another one, I'd look at the mesh satellites and not extenders. They'd integrate with the system.
Buyamac
Sounds good. However if I determine I need to add something to the third floor, can I hardwire a satellite and add it to the current mesh or is the extender the correct product?
Oct 24, 2020Guru - Experienced User
