WyzeInstall
Nov 14, 2022Aspirant
Add device to 2.4Ghz
I'm trying to add a Wyze Cam Pan v2 (indoor security camera) to my AC1750 R6400, however the Wyze can only connect to 2.4Ghz. How do I get the router to recognize the device - in non technical termin...
WyzeInstall
Nov 16, 2022Aspirant
From 2.4Ghz, I disabled (switched off) the private IP address on the phone. I don't have a subscription to iCloud relay, so there was no option to disable it. I waited two minutes and then tried to connect to the internet, which failed - the QR code never came up on the phone, because it couldn't connect to the internet. I waited another two to three minutes and repeated the same process and got the same result.
I also tried this: https://support.wyze.com/hc/en-us/articles/360031481351 rebooted the router and modem, waited five minutes and never got an internet connection.
I went through this process as well: https://support.apple.com/en-us/HT204051 rebooted the router and modem, waited well over five minutes and never got an internet connection.
Question: Can I move far enough away from the router to force a 2.4Ghz connection or do I need a specific phone / router combination for it to work? This was something I saw on an Apple help site.
Nov 16, 2022Guru - Experienced User
1. do other devices work fine? Just the wyze camera with issues?
2. you don't need to force anything. You can turn off smart connect (if that router has it) to make sure to have separate 2.4ghz/5ghz networks. Then you just make sure to connect the phone to the 2.4ghz.
- WyzeInstallNov 16, 2022Aspirant
Yes, the phone and Firestick work fine on Wi-Fi, albeit 5G. Only the Wyze camera will not connect, but I can't get a 2.4Ghz connection.
I did a search for "Smart Connect" from the routers search bar and I did not anything associated with my router.
- michaelkenwardNov 16, 2022Guru - Experienced User
The manual for the R6400 does not claim to support "smart connect".
- williamhokeNov 18, 2022Tutor
To connect your Android device to a 2.4 GHz network:
Unlock your device and tap the Settings app. Tap Network & Internet > Wi-Fi. Enable Wi-Fi by tapping Use Wi-Fi at the top. Select a 2.4 GHz Wi-Fi network. ... If prompted, enter the password for the network.
Regards: https://apkholder.com/
