WyzeInstall
Nov 13, 2022Aspirant
Add device to 2.4Ghz
I'm trying to add a Wyze Cam Pan v2 (indoor security camera) to my AC1750 R6400, however the Wyze can only connect to 2.4Ghz. How do I get the router to recognize the device - in non technical termin...
WyzeInstall
Nov 15, 2022Aspirant
Yes, the phone and Firestick work fine on Wi-Fi, albeit 5G. Only the Wyze camera will not connect, but I can't get a 2.4Ghz connection.
I did a search for "Smart Connect" from the routers search bar and I did not anything associated with my router.
michaelkenward
Nov 16, 2022Guru - Experienced User
The manual for the R6400 does not claim to support "smart connect".
