AlRom27
Sep 30, 2023Follower
Adding a VPN
I'm a novice and I'm trying to add PIA VPN to my router. I can't seem to log into my router setting.
michaelkenward
Sep 30, 2023Guru - Experienced User
You may need to talk to the people who supply the VPN. (Is that PIA?)
If it requires custom firmware on your (anonymous) router, Netgear won't support it.
- plemansOct 02, 2023Guru - Experienced User
michaelkenward is correct. PIA requires compatible routers to install to as its 3rd party firmware. You'd have to check with them if its compatible.
