AlRom27
Sep 30, 2023Follower
Adding a VPN
I'm a novice and I'm trying to add PIA VPN to my router. I can't seem to log into my router setting.
michaelkenward
Sep 30, 2023Guru - Experienced User
You may need to talk to the people who supply the VPN. (Is that PIA?)
If it requires custom firmware on your (anonymous) router, Netgear won't support it.
Oct 02, 2023Guru - Experienced User
michaelkenward is correct. PIA requires compatible routers to install to as its 3rd party firmware. You'd have to check with them if its compatible.
