cyoung299's avatar
cyoung299
Follower
Jan 28, 2023
Adding additional router to Nighthawk R6400
Limited knowledge, so be gentle please.  I have a Nighthawk 6400 that I want to add an R6100 onto.  Goal is to extend the range of my wireless network by means of ethernet cable to locate the R6100 a...
  • microchip8's avatar
    Jan 28, 2023
    - Set the R6100 to AP Mode (Access Point Mode)
    - Connect the R6100 with a cable to one of the LAN ports on the R6400
    - Configure the WiFi on the R6100. Make sure to use a different channel than on the R6400 for both 2.4 & 5 GHz. You can find the IP address of the R6100 in the R6400's connected devices. I recommend reserving an IP address for the R6100 on the LAN/DHCP page on the R6400 so it always gets the same IP from the R6400. You can do this by logging in to the R6400 using a browser and http://routerlogin.net or http://192.168.1.1
