Jemtee
Apr 21, 2020Aspirant
Adding an additional EX2700 extender
Hello I need some simple guide on how to add an additional extender EX2700 to my network. I have one already successfully added. The second one won't connect via WPS. So I went to the online i...
- Apr 21, 2020
1. Make sure you shut off the other extender while you're setting up the new one. you can power it back on once the new one is setup.
2. what router are you connecting to?
3. Have you tried going through setup using the installation wizard and not the wps method? Tends to work better when wps doesn't.
Apr 21, 2020Guru - Experienced User
Jemtee
Thank you so much - swtiched off and did via the browser and working a total treat. Simples really but not to me so thanks again
