chottosojib
Jun 14, 2022Follower
Admin and password is not working
I forgot my security question ..how can i updated ? admin and password is not working Please I Need Help...!
michaelkenward
Jun 16, 2022Guru - Experienced User
What for? Which Netgear device?
If you can't remember the details and don't have password recovery enabled your only solution is to reset the device back to the factory settings. Then use the default password.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
After you have set the device up again on your network either note down the new password somewhere that it won't get lost or enable and setup password recovery. To find out how that works, read the manual:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Password Recovery.
