Wernfried
Jan 21, 2017Aspirant
Admin page not shown properly
I have a problem with admin page of my router. After loggon I see page like this, the overview panels are missing and menues are disarranged. It applies on Firefox and MS Explorer. Do I ha...
- Feb 09, 2017
Actually I found the solution. In Kasperski you have to go to
Settings -> Advanced -> Network ->
Disable checkbox for "Inject script into web traffic to interact with web pages"
Best Regards
Wernfried
ElaineM
Jan 23, 2017NETGEAR Employee Retired
Welcome to the community, Wernfried
Do you have any Kaspersky installed on the business laptop?
Do you have the latest software for browsers and Firefox and MS Explorer?
Did you try to reinstall Firefox?
I'm not getting any error with Firefox nor Internet Explorer. What versions are you running for these 2 browsers?
Wernfried
Jan 24, 2017Aspirant
Obviously it is related to my Kaspersky Internet Security.
Kaspersky Internet Security is not installed on my business laptop and it works fine when I disable Kaspersky Internet Security temporarly.
Now the tricky question is: Which option/feature I have to disable, resp. where I have to define exception rule?
Best Regards
- ElaineMJan 24, 2017NETGEAR Employee Retired
Try to see if the instructions from this article will help.
- WernfriedJan 24, 2017Aspirant
I also found this article bit it dit not work
Wernfried
Based from what I read, Kaspersky's asking users to change their LAN IP address to 192.168.2.1.
Can you try that?
Access the admin page and change it under Advanced > Setup > LAN Setup
