Qwan1
Jun 30, 2022Follower
admin password recovery
R6220 All I am unable to obtain my admin login information. I am having a hard time with my teenager and I need to change the wifi password.
michaelkenward
Jul 01, 2022Guru - Experienced User
Have you tried the default settings. See the label on the thing.
If that doesn't work, then plemans is spot on.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
