bryan441
Feb 28, 2020Star
Admin password
Hello Guys ! I forgot my router password. Is there any other way to recover the password without resetting my router? Thanks.
- Feb 29, 2020
Unfortunately, your WNR612v2 is too old (2010) to support "password recovery". That's a "new" (around 2013) feature.
If memory fails you:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
antinode
Feb 28, 2020Guru
> [...] Is there any other way to recover the password without resetting
> my router?
A settings reset is the usual remedy for a lost password. Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Look for "reset".
bryan441
Mar 01, 2020Star
Thanks, both of you antinode michaelkenward.
On User Manual there is NO other option to recover the password without resetting router:mansad:.
I already reset my router:smileyhappy:.
