richard42ack
Aug 01, 2021Guide
Admin won't stay logged in for more than a dozen seconds
It has become impossible to manage the router. The routing is working fine otherwise. All clients are being serviced. Indeed, I am using it now to post this. Bandwidth and latency are very good. No i...
richard42ack
Aug 10, 2021Guide
Clocks are fine. I briefly managed to get into the NTP page and they accurate to the second.
How, then, does one mess up a token to the point that it requires a re-login within a few seconds?
If the clock is right, and the token has a reasonable validity, what is the mechanism by which this thing keeps logging out?
I looked into the code a little and started experimenting with current_date. It seems that I can set this in the url to get a little more time out of it. I cannot figure out the relationship yet, but a few minutes into the future will allow me to ping about 6 menu items before it logs out. Values well into the future seem to be counter productive.
Could be coincidences, anything is possible, but so far got 2 successful runs out of it using approx 4 minutes into the future. That better than I have managed for the past week.
richard42ack
Aug 10, 2021Guide
So this little trick of buying myself a little more time on the logins allowed me to find out some more about what was going on.
The status indicators contained errors. For example, it showed one wired device and another wireless device as attached when they were not. Refreshing did not change things.
It is clearly confused about something or other. This is fine, if it wasn't for this awful login business which seems to be fundamentally flawed. Not being able to stay logged in makes it near impossible to administer and find the problem. At this point, it seems more of a Netgear having hiccuped than a configuration issue. (2 reasons: 1 because nothing had changed recently, and 2, everything else is working fine). Either way, wherever the problem is, being able to get into administration to figure it out ought to be the most basic thing that absolutely has to work -- always.
- antinodeAug 10, 2021Guru
> re-login within a few seconds?If fiddling with the time changes the behavior, then I'd wonder about
timezone/DST confusion. I seem to recall seeing complaints here about
both NTP and timezone/DST problems on various models/firmware versions.> [...] being able to get into administration to figure it out ought to
> be the most basic thing that absolutely has to work -- always."always" is another of those tricky "time" concepts. If all you
need to use this thing is a simple time machine, then what kind of
whiner are you?Have you tried any different/older firmware versions?
- richard42ackAug 10, 2021Guide
OK. Here's what I did. I don't know why this worked, or if it would work for anyone else, but I will add it here for the record. And for anyone desperate enough to want to try anything.
I modifed the login url to look like this...
https://accounts.netgear.com/login?....¤t_date=2021:08:09:22:10:51
Where the only thing I changed was to add the ¤t_date= item.
This was set to 3 minutes into the future each time I logged in.
This gave me about an extra 30 seconds of login time. This extra time was just enough to bounce around and see problems, to shut things down and clear apparent errors. Without this hack, I had no chance of seeing anything, it just logged out far too fast. Both the fast logouts and this extended one were employed over many many cycles, so it was not a fluke.
After the cleanups, it is now allowing the usual admin operations.
Whatever the problem was, it had persisted for about a week.Note there is an apparently malformed todo= item. That is not a typo. Someone else can look into that one.
- michaelkenwardAug 10, 2021Guru - Experienced User
Seriously impressive work there on your part. Good of you to report back.
If you want to pursue anything else with your WAC124, or get a message through to the Netgear minders who watch that device, you might like to drop by in the appropriate section for this hardware:
Business Wireless - NETGEAR Communities
There are things in there that might have reduced your frustration:
Search - NETGEAR Communities – WAC124
Apologies for not spotting this earlier. But it is all too easy to get lost in the mess of a "community".
That whiner comment was totally uncalled for.
@ https://community.netgear.com/t5/user/viewprofilepage/user-id/80637
That's OK (when we finally get the right result). I realize these things can be troublesome, although it is easy to forget that when things are not going right. What is more interesting perhaps is what happens after a problem is figured out.
There are a some interesting findings in there, and it would be possible to do better. For example: re-authorization should be guardbanded with sanity checks to ensure it doesn't prematurely keep logging someone out. The current situation suggests that a naive perfect-world assumption drove the design. How exactly it failed may also be interesting to consider. Normally tokens are checked for expiration before advancing further. Yet the clocks were correct, and the NTP used was that from Netgear. Difficult to understand how that went wrong. I wonder if the normally short timeouts were actually intended, or represent some aspect of the same bug/issue related to this.
More difficult would be to figure out why some incorrect entries were kept active for an extremely long time (about a week) when they should have been history. Now I did reboot this thing early on, but didn't keep trying that after it turned out not to work. The main reason not to keep rebooting it was that I had people actively using it for work. So, without some indication it would fix the problem, it was an expensive option. Apart from the admin issue, it was working fine. Accordinging, I bought a new router and started transitioning clients there, but managed to come up with this solution before reaching the point of decommmisioning.One comment in this thread sadly suggests that at least some do not take customer input seriously and/or simply do not care to address the issues.
Thanks,
Richard.
I don't know which comment that was, but most of the reponses here are from other users rather than anyone at Netgear.
There is a small team of official minders who do their best with limited resources. Like most people, though, they probably show more sympathy to people who come across as reasonable individuals. Hang around here for any time and it won't be long before you come across unacceptable behaviour and downright rudeness.
A lot depends on the problem and the device involved. That is why I should have been quicker off the mark.
Some products seem to get more attention that others. Perhaps it reflects the price tag. (For example, gaming routers have their own specialists who are quick to respond, as they should given the cost of those things.)
Pro devices like the WAC124 certainly have their own specialists and, when you hit the right section, less noise traffic to drown out the real signal.
Those gadgets are very different from the consumer stuff that usually comes up in this section which, let's face it, sits at the bottom of the food chain in technology, cost and consumer understanding. As you may have worked out, I've never been let loose on business devices.
https://www.google.com/search?q=sarcasm+wasted
> 1 Kudo
_That_ was predictable.
- richard42ackAug 14, 2021Guide
Fair enough.
It is hard to tell sarcasm from intention based upon text messages though, unless you happen to know the person well.You could presume that my response was also sarcastic...
But no, not true, I got it wrong there. Oops. My mistake there.
Anyway, after a week or so of greatly improved behavior, I would take a fairly reasonable guess that the underlying admin timeout issue has a fundamental flaw or bug in it. This would be behind many of the other threads related to this issue. The fixes in those cases were more likely to be happen-stances that avoided running into the real bug.
Today for example, someone reported that the printer was inaccessible. I got into the router and found that I was getting about 5-6 clicks before logging me out. So it seemed to have regressed a bit. It was better than before when 2-3 clicks was the norm, so that was a little more workable. A few days earlier, it seemed there wasn't a limit.
What I also found was that the printer was listed as on-line, but without an IP address. Checked if we had run out of them (dhcp), no. Power cycled the printer, and it came back on line. Oddly, it was still listed as online even when it powered down, and everything refreshed in the router. Who originally created the problem isn't my issue (who knows). It seems that one apparently-unrelated problem triggers and/or exposes another.
The problem is that the admin should stay logged in long enough to find out where the problem might be.Richard.
- richard42ackSep 23, 2021Guide
And today, the problem is back again. Absolutely nothing has changed since it was last working.
Need to add another machine to the network, but the thing is logging me out before I can get there. What the heck is wrong with this thing? What basic bit of logic is in there that doesn't allow a session to exist for more than a handful of seconds?
It was a dumb idea to route all the logins this way in the first place -- a technology that Netgear have not either thought through or executed properly. Avoid ! as it doesn't seem they will either correctly identify or fix the issue
- michaelkenwardSep 24, 2021Guru - Experienced User
This may sound like an odd one, but I recently had a problem on an R7800 that I fixed by disabling:
Always Use HTTPS to Access Router
Buried in Web Services Management, it seemed to get in the way of using a browser alongside an app to access the router.
That setting was probably a response to requests for more secure access to the graphical user interface. As implemented it seems to upset things.
It may or may not have anything to do with what you see, but it might be worth trying.
- richard42ackSep 24, 2021Guide
Thanks for the suggestion. It seems that it may make sense in that this appears to be a token issuing problem. Such things are time sensitive, and my thought is that there is some clock skew/drift going on. The apparent flaw in the design is that once a token is obtained, it should be valid for a reasonable period without being re-checked. Whatever they are doing seems to be resulting in incorrect attempts to obtain new and unncessary tokens.
My thought is that the clocks have drifted somewhere (even though they are supposed to be all sync'd) and that is a factor.
I haven't found anything suggesting mine was having some https issue, at this point. But I appreciate the suggestion.One brute force approach would be to disconnect it from the internet and thus deny it the means to try to do sso over the internet. However, all users would then also be kicked out, unless I can figure out a more selective means of doing it. In the meantime, I have added another router to the network and added the device there instead.
Thanks,Richard.
- michaelkenwardSep 25, 2021Guru - Experienced User
Another thought, there is a discussion under way on the "Idea Exchange" section. It does not quite fit in with your problem, with a very short interval, but it is along the same lines.
Admin Timeout - NETGEAR Communities
- richard42ackSep 25, 2021Guide
wrt very short timeout link posted: Yep, it was always bad in that regard too.
Did they really mean it to be so short, or did it get messed up in some fundamental way that caused both of the problems? My guess is the latter. The timeout was always so ridiculously short that it is difficult to believe that anyone would have deliberately made it that way.
Richard.
- richard42ackOct 11, 2021Guide
Latest update in here is that the solution to the problem is...
Turn mu-mimo off.
Richard.
- richard42ackOct 13, 2021Guide
Well, not quite. There were 2 things that were done, and it seems undoing either of them brings the problem back again. The first is to disable mu-mimo, as noted previously, the other is to enable access to wired ports. I don't know if there is any rhyme or reason to that. But once the immediate problem is addressed, the other problem that others have spoken of (very short sessions before logout) also seems to be solved.
What I notice is that some requests, such as getting the current list of devices take many seconds to execute. It ought to be a simple local lookup, so not sure which scenic route it might be taking. Or what might be delaying it.
Richard.
- FURRYe38Oct 13, 2021Guru - Experienced User
I would perhaps contact NG support
https://www.netgear.com/support/#
or a forum moderator over in this more appropriate forum to express your experiences to:
You might get/find better information here:
https://community.netgear.com/t5/x/bd-p/business-wireless-for-business
