Franked
Jul 08, 2021Aspirant
Advice for a new Access point P router
Hello I'm now using a R6220 and I'd like to find a newer model from Netgear. I deactivated the wifi from my ISP box, and I'm using the Netgear Router only in access point mode, to create a home ...
Franked
Maybe I'm asking for something too complicated. If I reduce my criteria to only having stronger wifi signal than the R6220, what would you suggest ? Router will be in AP mode only.
- olympos1625Jul 13, 2021NETGEAR Employee Retired
Hi Franked,
Welcome to NETGEAR Community!
Thank you for reaching out. You may check this link instead for our WiFI 6 routers.https://www.netgear.com/home/discover/wifi6/
You may check these models RAX10, RAX20, RAX35 or RAX40.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
