Franked
Jul 08, 2021Aspirant
Advice for a new Access point P router
Hello I'm now using a R6220 and I'd like to find a newer model from Netgear. I deactivated the wifi from my ISP box, and I'm using the Netgear Router only in access point mode, to create a home ...
Franked
Maybe I'm asking for something too complicated. If I reduce my criteria to only having stronger wifi signal than the R6220, what would you suggest ? Router will be in AP mode only.
olympos1625
Jul 13, 2021NETGEAR Employee Retired
Hi Franked,
Welcome to NETGEAR Community!
Thank you for reaching out. You may check this link instead for our WiFI 6 routers.
https://www.netgear.com/home/discover/wifi6/
You may check these models RAX10, RAX20, RAX35 or RAX40.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
