laserman
Dec 04, 2015Tutor
After Firmware upgrade, unable to access DDNS
Two days ago, I accessed my router page (AC1450) and found a banner telling me that a firmware upgrade (V1.0.0.34_10.0.16) was available so I allowed it to occur. Since then, I'm not able to acce...
- Dec 12, 2015
After posting this, I called Netgear support. My router was out of warranty so there wasn't much I could discuss with the rep outside of paying an exhorbant fee for an answer. I was directed to the FAQ page for answers.
Fault on my part and fault on Netgear.
First, I did get the router back up and operational. My fault was, I didn't make a backup of the existing information. Netgear's fault, it didn't prompt me to do any of that after I clicked on the ballon to upgrade the firmware from the status page of the router.
If you're going to put a prompt up that there is an upgrade available for a router, then Netgear needs to inform the end user that there are steps that need to happen or else data will be lost.
I ended up downgrading the firmware, downloading the firmware from Netgear and then upgrading to the most current firmware, then instilling all of the information from scratch into my router and I was able to communicate with my computer from remote through DDNS.
laserman
laserman
Dec 04, 2015Tutor
And for some unknown reason, it posted this in the R6000 series router page.
- DexterJBDec 06, 2015NETGEAR Moderator
Hi laserman,
Did you perform a factory reset after the successful firmware update? If not, I recommend doing so then you can reconfigure all the router settings again.
Dexter
Community Team
- lasermanDec 12, 2015Tutor
laserman
