laserman
Dec 04, 2015Tutor
After Firmware upgrade, unable to access DDNS
Two days ago, I accessed my router page (AC1450) and found a banner telling me that a firmware upgrade (V1.0.0.34_10.0.16) was available so I allowed it to occur. Since then, I'm not able to acce...
- Dec 12, 2015
After posting this, I called Netgear support. My router was out of warranty so there wasn't much I could discuss with the rep outside of paying an exhorbant fee for an answer. I was directed to the FAQ page for answers.
Fault on my part and fault on Netgear.
First, I did get the router back up and operational. My fault was, I didn't make a backup of the existing information. Netgear's fault, it didn't prompt me to do any of that after I clicked on the ballon to upgrade the firmware from the status page of the router.
If you're going to put a prompt up that there is an upgrade available for a router, then Netgear needs to inform the end user that there are steps that need to happen or else data will be lost.
I ended up downgrading the firmware, downloading the firmware from Netgear and then upgrading to the most current firmware, then instilling all of the information from scratch into my router and I was able to communicate with my computer from remote through DDNS.
laserman
laserman
Dec 04, 2015Tutor
And for some unknown reason, it posted this in the R6000 series router page.
DexterJB
Dec 06, 2015NETGEAR Moderator
Hi laserman,
Did you perform a factory reset after the successful firmware update? If not, I recommend doing so then you can reconfigure all the router settings again.
Dexter
Community Team
- lasermanDec 12, 2015Tutor
laserman
