Donmenz
Sep 01, 2017Aspirant
After installing a new wireless printer, my Netgear login info changed, can't get back online!
Just installed a new Canon wireless printer. At setup the directions had me push the button on the router, so that the printer software could find it. Afterwards, instead of coming up as NETGEAR for ...
- Sep 02, 2017
Thanks for your interest in my problem! On a whim, I called Microsoft, and they solved the (minor) problem. Seems that when i hooked up the new printer it just changed the router ID from what I was used to seeing. They just renamed it, and I made up a new password and we were good to go! If I was just a bit more tech savvy....
michaelkenward
Sep 02, 2017Guru - Experienced User
Which button on the router? WPS?
Which router is this?
Is NTGR bt1Z9dj....etc the SSID you see?
