Sethos099
Jan 28, 2016Aspirant
After scanning my PC- WARNING Vulnerability ID: NON-2015-0211, help please
The report said my firmware was out of date and needed upgraded. So, like any reasonable computer geek I checked your site and found the upgrade you suggested to others with the same problem.... up...
ElaineM
Jan 28, 2016NETGEAR Employee Retired
Hi Sethos099 The firmware will depend on what model number you're using.
Can you let me know the exact model number and version of your NETGEAR device?
- Sethos099Jan 28, 2016Aspirant
Thank you for your quick response, N600 Wireless Dual Band Gigabit Router- Premium Edition, Model WNDR 3800, v 1.0.0.48. I hope this helps, any further questions please feel free to email me back.
Thank you again,
Sethos099- ElaineMJan 28, 2016NETGEAR Employee Retired
Unfortunately, there will be no future firmware updates for the router.
It's because the router is already EOL.
Consider getting a newer model.
Thank you Elaine for taking the time to research and check... and, also break my heart a little ;). I really do like the router; but, it seems I must religate it to the "Recycle Bin" in the sky lol.
Thank you for you attention to my question, my next router will be another NETGEAR, in large part, based on how you handled me inquery :)
Sincerely,
Sethos099
