SunilS
Jan 15, 2023Aspirant
AirPrint (Bonjour) does not work on my Netgear R6080 WiFi router
AirPrint (Bonjour) does not work on my HP Envy 4520 printer that is connected to my Netgear R6080 router (firmware version 1.0.0.54) via wireless connection. It works after I reboot the printer. Afte...
Jan 16, 2023Guru - Experienced User
1. what modem/gateway is the router connected to?
2. have you went into the router and sent the printer with a reserved IP address?
michaelkenward
Or on the printer itself?
How you do that depends on the printer's controls.
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
