SunilS
Jan 15, 2023Aspirant
AirPrint (Bonjour) does not work on my Netgear R6080 WiFi router
AirPrint (Bonjour) does not work on my HP Envy 4520 printer that is connected to my Netgear R6080 router (firmware version 1.0.0.54) via wireless connection. It works after I reboot the printer. Afte...
Jan 16, 2023Guru - Experienced User
1. what modem/gateway is the router connected to?
2. have you went into the router and sent the printer with a reserved IP address?
SunilS
Jan 17, 2023Aspirant
Thanks for your reply. I have an Arris TM822R DOCSIS® 3.0 Telephony Modem connected to the router. Thanks for your suggestion. I presume that, by a reserved IP address, you are referring to a static IP address. I will allocate a static IP address in the router for the printer.
