WantNotTexhNot
Mar 13, 2025Aspirant
All internet settings on router vanished after I changed the SSID password.
As stated above, additionally, my main PC, now plugged into LAN on router, reads as 'Device is blocked by Access Control in the router'. Other PC will connect wirelessly, and the internet settings ...
CrimpOn
Mar 13, 2025Guru - Experienced User
If the router will not allow access, there is no opportunity to make any changes. Although a Factory Reset is often thought of as a Last Resort (because it erases any configurations the user may have done - in my case about two hours of typo-ridden entries), this seems to the situation here.
I would Factory Reset this unit and start from scratch.
WantNotTexhNot
Well, the odd thing is, it will connect, qnd allow access to router through the additional SSID , which connects at 2.4GHz, but will not allow the settings to 'stick,' as it were.
So, basically, I am operating the PC which will connect without any info on the Subnet and other items visible to me in the settings,, and without being able to unblock the ip address of the other device.
Can't even think about a total reset, as it makes my sromach curl.
Thanks
Thanks
