Doug_Allison
Jul 08, 2021Follower
Alternate flashing Power/USB Lights
I tried to update my AC1600/R6260 wifi router and all I get now is alternate flashing power and usb lights. I cannot hardreset and the update doesn't work. Is it now bricked?
saintbump
Jul 14, 2022Aspirant
I have ran into this issue recently. I have not found a working solution. None of the above have helped. The reset button is unresponsive, and TFTP is unresponsive. If I hold the WPS when booting the boot sequence takes a moment longer, though no access through ethernet that I can find. When holding the WPS button the power light and internet light stay steady momentarily before reverting back to the flashing between power and USB.
If anyone has any other ideas on how to return this to a state that can be flashed that would be great. Thanks
michaelkenward
Jul 15, 2022Guru - Experienced User
What have you run into recently? Alternate flashing Power/USB Lights? (The subject of this conversation.) Or a TFTP failure?
Do you have the same hardware?
What does "unresponsive" mean in both cases?
What happens when you press the reset button for 20 seconds? Have you tried the more severe version?
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
How is TFTP unresponsive? What happens when you try it.
This is a complicated process that comes with all manner of messages and prompts and is very sensitive to timing.
Why are you pressing the WPS button? Is isn't a part of the recovery process.
Unfortunately, Doug_Allison didn't get back so this year old conversation fizzled out with no resolution.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, you might do better to start your own discussion.
