gerald02020
Oct 22, 2021Aspirant
Alternative zu WNDR4500 gesucht
Ein nettes Hallo mal in die Community, Ich bin auf der Suche nach einem Ersatz für mein Netzwerk. Grund des tausches: Die Router sind nun mit Stand 22.10.2021 zu langsam. Aufbau: Internetm...
Oct 23, 2021Guru - Experienced User
why not go with a mesh system so you can use the wired backhaul?
Then you can add satellites as needed for addional coverage and have seamless roaming
- gerald02020Oct 23, 2021Aspirant
Hello,
Well I don't know the new tecnnic.
Orbi Mesh RBK853 or SXK80B3 or I change only the main router to a RAX200.
But to me the problem is that my Modem have since 22.10.2021 downloadspeed 500mbit/s Uploadspeed 50mbit/s. And in Future maybe much faster. So a Orbi System be maybe a wasted money system, because no 10gbit network for ~1100€ for the RBK853. I search a system without abo but with good speed, connection and safe for future.
The limit from the WNDR4500 be 425/50 (speedtest) the router have 1Wan/4Lan with 1gigabit Network and 450mbits WLan.
The thing be that the wndr4500 have great security, because MAC filter. And it did it by LAN and WLAN! So that mean that f a PC without the MAC Adress be connected, no IP, no Network., I know that, because I forgot in Past to enter a PC Mac adress and after restart no enter to network or internet. So I have to reset the router to factory.
The Fritzbox 7590ax only do the Mac Chac by WLan, that mean if someone connect after fritzbox, the guy have access to it. Sure I can kick them out of the network after he was there. =(
So that was one point why I send that back.
To me the Network cable are there (Cat 7 cable to cat 6 network box).To me I have no Problem to change accesspoint or the whole System.
But the point be that Safety and WLan Speed should be open for future and not just for one or 5 years.
I also look about the xr700 and was shocked. 450€ a few years ago and now? Which one have a fast Network or 10 gigabit...
The network speed is by 1 gigabit and not faster. so boring.
A router or a mesh system should be faster after 11 years. I was shocked as I saw the technic data of orby and co.
I search something for future. fast and safety - gerald02020Oct 25, 2021Aspirant
Do you know the speed of the WAN maximum from the Orbi System RBK853?
- FURRYe38Oct 26, 2021Guru - Experienced User
The RBR 8 series has a 2.5Gb connection rated WAN port.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
