gerald02020
Oct 22, 2021Aspirant
Alternative zu WNDR4500 gesucht
Ein nettes Hallo mal in die Community, Ich bin auf der Suche nach einem Ersatz für mein Netzwerk. Grund des tausches: Die Router sind nun mit Stand 22.10.2021 zu langsam. Aufbau: Internetm...
Oct 23, 2021Guru - Experienced User
why not go with a mesh system so you can use the wired backhaul?
Then you can add satellites as needed for addional coverage and have seamless roaming
gerald02020
Oct 25, 2021Aspirant
Do you know the speed of the WAN maximum from the Orbi System RBK853?
- FURRYe38Oct 26, 2021Guru - Experienced User
The RBR 8 series has a 2.5Gb connection rated WAN port.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
