gt2526
Dec 04, 2020Tutor
amber upstream light on solid
anyone find a fix for this? seems to happen alot comcast guy coming this weekend unit has current update from comcast. Firmware V3.01.12 seem to have same problem as most others only 1 channel loc...
Dec 05, 2020Guru - Experienced User
You can check the cable for splitters, amplifiers, or attentuators and remove them if you have them.
check the coax cable for kinks, damage, cheap/bad connectors, loose connectors.
Preferably, move the modem to right where the coax enters the home to prevent extend runs or issues internal to the wiring of the home.
If that doesn't help then the comcast person does need to check the lines.
gt2526
Dec 05, 2020Tutor
I have no amplifiers, or attentuators, only have 1 splitter
With 2 outs, 1 side to the TV and 1 side to cable modem.
replaced spltter last night, no change.
Still have light and it just drops off line when it wants but shows to be connected.
- plemansDec 05, 2020Guru - Experienced User
did you have the cable guy check the line?
- gt2526Dec 05, 2020TutorComcast came , changed 4 fittings in the house and 2 outside
1 was at the outside cable junction box.
Seems to have corrected things for know.
All the upstream channels are connecting.- plemansDec 06, 2020Guru - Experienced User
sounds like it must have been an issue with one of the splitters/connections.
glad to hear its fixed. if you mark it solved, it can help the next person.
