Mizumi
Feb 28, 2021Follower
Any affordable Router with DFS Support?
Hey guys, I need an any affordable router with a DFS channel support on 5Ghz band. I'm not necessarily talking about creating an AP on DFS channel but I am planning to use the router in client mode ...
roger_h
Jul 01, 2021Aspirant
I'm likely to late for you? But after a long chase of any DFS channels, I settled with a EX7000 AP and EX7000 EXT pair. I bought a refurb ex7000 to replace the r7000p I waited to long to be able to get rid of it. Since my moden had a router built in I went the AP/EXT route to get from barn to house. The EX7000 I bought with 2 year warrenty for $50. As far as I can see this will work for me for at least 2 years. Then If netgear actually unlocks DFS on the R7000P I will use it again? Or try DD-WRT? So now I do have DFS to barn and avoid 2g where no one used only 1 6 11 and some use 40mhz wide on 2,4,8 slowing down everone else. I am at a place in Maine on vaccation that has an AX20 WIIFI 6 with no DFS. LizardSystems WI-FI shows only non DFS channels in advance details. I have little faith that any vendor will give DFS in lower priced device in the next two years. In hindsight I would have bought to cheap refab instead of R7000P and EX7000. Live and learn!
Roger
