emv1031
Jun 22, 2016Aspirant
Any way to reset via admin interface?
I have been having connection issues with this router. It´s pretty much new (a few weeks old), it was working fine but then a few days ago it started with random disconnections. The internet doesn´t ...
Retired_Member
Jun 22, 2016Hold reset until power led flashes or log in and go to advanced ....back-up settings....choose erase...revert to factory default
- ElaineMJun 23, 2016NETGEAR Employee Retired
emv1031 Yes, you may access the admin page of the router and you should be able to see it under Advanced > Administration > Backup Settings > Revert to Factory default settings.
- emv1031Jun 23, 2016Aspirant
Thank you to both repliers... that´s exactly what I was looking for. The reset button decided to take a permanent summer vacation and just wouldn´t work. I reset it with the info you both provided and seems the disconnection issues are gone.
Thaks!!
