emv1031
Jun 22, 2016Aspirant
Any way to reset via admin interface?
I have been having connection issues with this router. It´s pretty much new (a few weeks old), it was working fine but then a few days ago it started with random disconnections. The internet doesn´t ...
Retired_Member
Jun 22, 2016Hold reset until power led flashes or log in and go to advanced ....back-up settings....choose erase...revert to factory default
ElaineM
Jun 23, 2016NETGEAR Employee Retired
emv1031 Yes, you may access the admin page of the router and you should be able to see it under Advanced > Administration > Backup Settings > Revert to Factory default settings.
- emv1031Jun 23, 2016Aspirant
Thank you to both repliers... that´s exactly what I was looking for. The reset button decided to take a permanent summer vacation and just wouldn´t work. I reset it with the info you both provided and seems the disconnection issues are gone.
Thaks!!
