mdj1973's avatar
mdj1973
Anyone else having trouble with loading websites on Steamdeck?
I have a Netgear R6260 router and recently got a Steamdeck. I read reports on reddit of several users who are having trouble getting websites to load on the steamdeck through a browser. I am having this too. Some sites load without problem - such as Youtube - others will take very long to load if at all. What these users have in common is Netgear routers.
Relevant discussion on Reddit: https://www.reddit.com/r/SteamDeck/comments/whgavp/certain_websites_not_loading_on_my_new_deck_but/
  • What modem gateway do you have the router connected to?
    Do you have IPv6 enabled?
  • plemans's avatar
    • mdj1973's avatar
      mdj1973
      Thanks for your response, I did not have IPv6 enabled. I enabled it on the router as "Auto detect" and enabled it on the steam deck as "Automatic". Unfortunately this did not fix the issue...
    • mdj1973's avatar
      mdj1973
      I spoke too soon, after some time it started working. Thank you for your help! I will share this as a potential solution with other users who I found with the same issue.
