sdamon
Jun 07, 2021Initiate
anywhere access and parent control
When I try to enable Circle parent control I get an error message "this operation not available using anywhere Access". When I try to disable Anywhere Access I get the same message. Can anyone help m...
sdamon
Jun 08, 2021Initiate
Thank you for responding. I do not have Nighthawk. I use the Orbi app on my phone to control the network. While I don't really want to disable anywhere access, I want to enable circle parent controls. I will try looking at the resources you suggested.
michaelkenward
Jun 08, 2021Guru - Experienced User
Replace Nighthawk with Orbi and the same advice applies.
