Dee_Bee's avatar
Dee_Bee
Follower
Sep 08, 2022
App features not working
Hi all,
I have the R6120 router yet, I don’t have all the app features. I can’t rename devices anymore, the dashboard screen only shows a pic of the router, device manager (only option to toggle on or off), Wifi settings, Guest wifi and support.
The app and firmware is up to date. Why don’t I have parental controls, speed test, proper device manager etc?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Is your R6120 in router or access point mode?
    Which app is this? Android? iOS?
    How were you trying to rename devices? There are at least three different ways of doing that: browser graphical user interface (GUI), app and desktop genie.
    Not sure that I follow the rest of that sentence.
    Can you access the router through www.routerlogin.net?
    Only the number of the firmware is a reliable indicator of that. If you have used the app to manage the router, there is a good chance that it is not as up to date as you think.
    Which type of parental controls do you expect to see? Netgear has removed the original version that came with your router.
    Why can’t I see the NETGEAR Smart Parental Controls tile in the Orbi or Nighthawk app after upgrading to the latest firmware? | Answer | NETGEAR Support
    By the way, I hope you don't have an Internet service faster than 100 Mbps. The R6120 is limited to a connection speed of 100 Mbps to the modem/internet. Anything faster than that is wasting your money.
