BerlinGoodMan
Jan 14, 2023Aspirant
Apps for N300 and should I get a new one?
Hello, I have been trying all morning to try and find support for my N 300 wireless router WNR2200. I’ve tried two of the apps (Nighthawks and Netgear Mobile), but this model is no longer support...
Dec 20, 2025Guru - Experienced User
with 100mbps service, you don't need a "top of the line" device. I'd check your local marketplace or used and get a device from last generation (it'll be much cheaper) that at least gigabit. You don't need 6ghz but if you plan on upgrading phones, its not always a bad choice.
