Markwatts
Nov 21, 2020Follower
archer 1600v router: sharing router connection via cat6 cable then back to Wi-Fi signal
Hi I have a Supplied archer v1600 TPlink, router sharing coms.
From there I have a cat6 cabling running from house approx 60metres away to my shed.
From there I need to turn cable connection back to Wi-Fi. I've tried older modems like a N300 and N600. But none seem to work what ever setting I try.
Can you recommend a product to use to convert incoming Cat6 cable back to Wi-Fi as house signal are to weak at this distance
1 Reply
> [...] I have a Supplied archer v1600 TPlink, router sharing coms.
Huh?
> [...] I've tried older modems like a N300 and N600. [...]
"N300" or "N600" is a speed, not a model number. Look for "Model"
on the product label.> Model: D3600|N600 WiFi Modem Router - 802.11n Dual Band Gigabit
Is "D3600" one of your actual model numbers?
> [...] But none seem to work what ever setting I try.
Think, for a moment, about how little useful information that
(non-)description conveys to the non-psychics in your audience.> [...] convert incoming Cat6 cable back to Wi-Fi [...]
You might want to configure one of your old routers as a wireless
access point.Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Look for a topic like
"Set Up the Router as a WiFi Access Point". Not all models have a
convenient option for this, but practically any model can fo it. See,
for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option.
