PattiChati
Aug 22, 2016Aspirant
Asking username and password after downloading new firmware
I am trying to download new firmare since I haven't done so in many years. It asks for my microsoft edge user name and password. I don't remember it, but did create a new password.
That doesn't w...
- Aug 22, 2016
At what stage is this?
Do you mean that you are using Microsoft Edge and it asks for a password to get into the Netgear router?
If so, try the usual defaults (admin/password).
If that doesn't work, then you can reset the JWNR2000v3 to these default factory settings.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The manuals and stuff are here:
JWNR2000v3 | Product | Support | NETGEAR
So is the firmware. You can download it and apply it locally.
michaelkenward
Aug 22, 2016Guru - Experienced User
