mrpat3
Mar 06, 2022Tutor
assigning ip address
I have 2 questions. 1) Some of my attached devices dont have an ip address assigned to them This is after using them, working fine. Most of my attached show the Ip address that is assigned by the ro...
mrpat3
Mar 06, 2022Tutor
Thanks for chiming in. Firmware is v1.0.0.52
3 devices show up as connected but no IP address. One is a label printer that I THINK have set up to a static IP because it used to drop out if powered down . Should be .200 but since the router doesnt display the IP I dont know. But it works.
One other is an old linksys wrt54g that I reloaded with ddwrt software and use it as kind of a range extender down at the barn. The 3rd I dont know what it is as I havent tied all the mac address devices with a name so I can track them.
The Modem is an ARRIS sb6183 with comcast
And for that email of the log, I dont have that button like it says i should for email of logs. Not there. And there are no neighbors nearby of any consequence...
mrpat3
Mar 06, 2022Tutor
I thought this might help, see attached
