bennettwrite
Nov 12, 2023Follower
Attempting network bridge from T-Mobile HotSpot to AC1200 Extender to N900 Router
I have a Franklin T10 mobile hotspot. It works great with one problem. It is restricted to 15 devices at most. With all the Wi-Fi bulbs and plugs I have I'm well over that. I have been told that con...
michaelkenward
Nov 12, 2023Guru - Experienced User
bennettwrite wrote:
I have been told that connecting a range extender as an access point and plugging a wireless router into the extender, that I can connect all of those devices to the wireless router and then the hotspot will register just one device.
You have been told what? That arrangement is likely to be a complete mess. You can't just keep piling bits on to a network and expect it to work,
For a start, two routers – the mobile hotspot and the N900 Router – lands you in immediate difficulties.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
This N900 Router could be anything, All it tells us is that it is an ancient device that has N900 wifi technology, which is a decade or so old.
Then there is the AC1200 extender. Again, that could be many things. AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
I have a second range extender with no brand names were markings anywhere. The only clue I have is that it uses 192.168.188.1 for login page.
That's just a local IP address that could be on an anything.
Netgear devices have a model number printed on the label on them
