David_M
Jan 01, 2021Tutor
"Attempting to connect to Netgear Server. Please Wait..." just hangs forever
Happy New Year everyone ! I upgraded new FW update today for my R8000p (V1.4.1.66_1.3.26). One of the fixes they said was improvements to QoS and Zoom calls. I tried to upgrade the database perfo...
Jan 01, 2021Guru - Experienced User
What speeds do you pay for?
Qos isn't recommend at speeds >250mbps.
- David_MJan 01, 2021Tutor
300/10 mpbs
Problem still exists whether QoS is off or on. In my case, with QoS ON, i repeatedly get 350/12 mpbs speeds. With it off, I may get up to 360/12 mpbs, maximum. Again, I pay for 300/10 mpbs only.
David
- plemansJan 01, 2021Guru - Experienced User
what modem/gateway do you have?
I was just saying that there isn't a benefit to qos above 250mbps speeds and can sometimes actually slow your speeds down.
So I'd leave it disabled anyway
- David_MJan 09, 2021Tutor
Thanks,
I have a newish motorola MB8600 cable modem (up to 6Gbps, Docsis 3.1). Less than 3 months old with latest firmware.
I use QoS as it helpouts out my online class zoom sessions. I'm in grad school to everything is online with many students logged in. Besides QoS on or OFF doesn't help with my problem, unfortunately. Do you have a problem upgrading the database like I do?
Thanks!
