DeJean1961's avatar
DeJean1961
Follower
Aug 25, 2022
attempting to reconnect my Wifi Extender to new home Internet
Trying to set up my Netgear Wifi extender to new T-Mobile 5G home internet, but not getting the prompt to do so on my PC or phone. I have hit the factory reset button, but not recognizing any Wifi Signal.
Any suggestions.
1 Reply
  • plemans's avatar
    What wifi extender do you have?
    When you factory reset, did you push and hold for 7-15 seconds while powered on?
    If so, the default ssid should be netgear_ext.
    Make sure not to hit the wps button if you're following that route of install.
