tdysnburger
Aug 22, 2017Follower
Authentication problem with my Kindle-Model R6400
My Kindle is showing authentication problems with my Netgear router. Any suggestions?
- Aug 28, 2017
Hi tdysnburger,
Please make sure that you enter the correct WiFi password when connecting. You can try forgetting the network then re-connect suing the correct password.
Dexter
Community Team
DexterJB
Aug 28, 2017NETGEAR Moderator
Hi tdysnburger,
Dexter
Community Team
DexterJB
Sep 04, 2017NETGEAR Moderator
Hi tdysnburger,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
