AbbottFamily
Aug 31, 2021Follower
AX8 AX6600 WiFi 6 Router Rax70 offline to internet (on netgear app too)
I am having trouble with the netgear router, AX8 AX6600 WiFi 6 Router Rax70, it keeps being offline to the internet and there is no LED light for the ethernet cable plugged in. I have reset it and re...
Aug 31, 2021Guru - Experienced User
What modem do you have?
How often is it happening?
Have you hardwired into the modem for a while to ensure the modem connection is good?
